206, check out my FREE video demos (glass apps, coroplast apps, etc.)
www.rapidtac.com
You can do a wet application (with rapidtac or TacII) on any sealed substrate.
Wood paper etc. that have not been sealed won't work.
The reason to use the wet application is to insure properly cleaned substrate for superior bonding (rapid Tac and TacII are cleaners, positioning fluid and adhesive stimulant all in one bottle.
They eliminate bubbles or misalignment.
Rapid Prep is a very strong water based solvent for deep cleaning of wax,grease,oil,silicone,etc. only necc. if you suspect fresh wax silicone etc..
The people that tell you you must wait more then 1 minute to remove transfer tape are NOT cleaning properly, following instructions means don't use other cleaning solvents or cleansers, and only use CHEAP paper towels to wipe with (they have not been saturated with chemicals) .
the "super absorbant/lint free" paper towels will contaminate and cause poor bonding and so will cloth towels or rags,which means waiting 30 minutes to remove trans tape, then never really having a good bond anyway , resulting in your vinyl not holding up to carwash sprayers!
Watch those videos, you'll see.
Roger
![Thumb :thumb: :thumb:](https://signs101.com/images/smilies-orig/standard/thumb.gif)
