Where are the fuses on Valuejet?
Mr. T
I have a Mutoh Valuejet 1204. My machine would not power up a few weeks ago and the service tech took the fuses out and put the same ones back in and it fired up. Now the same problem occured and I cannot find the fuses. Any ideas?
Thanks,
Tracy
signage
I would call the tech back and have them repair the unit, most fused do not just blow, either you are doing something wrong or the machine has a problem causing the fuses to blow!
sarge
maybe it is a slow blow fuze . but i agree .. something is amiss .. maybe a burnt transistor on the power supply .. i dont have your machine .. but my summa has a both an internal and external fuze .. the internal fuze might be on the power supply .. it is where i would look .. and do you power down your unit when not in use? .. just a thought
MacDaddy
Remove the back cover, the fuses are located on the right end as looking at it from behind. The are near where the AC Power Cord connects to the machine.
Mr. T
Fuses
Thanks Folks,
I unplugged the unit for about 15 minutes and whala she fired up. Has been fine all day. Very strange!!!
Thanks,
Tracy
