Like Mike mentioned, depending on what you are trying to achieve is the product you will need to use. We've used both flexible and rigid like GE and Sloan. GE contour product need to be heated but hold the letter shape really well. You can also route the acrylic and routed to give the neon look too. If you like to upload the design I can gladly help you out.If it is for something like Biglari signature that they put on Steak n Shake, that is a routed letter, filled with leds. You'd have to be careful finding fab shops that won't try to poach your customer from you. GE and Sloan do not offer finished products. You'd have to call someone like Bitro or SteelArt. This Biglari is no fun if it is fabbed badly. There is nothing to service except the power supply, so any outages means you have to refab the whole thing...
Can you provide a few examples - Trace@NorthStarSignsandGraphics.comHello JBurton, I own a small company that specializes in trimless channel letters that can be fabricated with clean edges and even illumination similair to the aforementioned acrylic block letters but with some distinct advantages.
