Which preset should I use? Versaworks.
Tony Rome
Just wondering what everyone uses for vehicle graphics or for outdoor aluminum signs?
Some of the presets are MAX Impact, Sign and Display, Pre-press US, etc... or is checking "specify profile and ignore default" the way to go?
Thanks!
Versacamm SP540v w Versaworks.
amw
Longtime Members
Thanks!
Depends what we are doing and what its printed on.
but usualy, signs & display or max impact.
Marsha
Tony Rome
Thanks! Anyone dare go with High Speed or do you stick with standard when printing vinyl laminated then mounted to aluminum signs for outside?
wwpro
US Press for bitmaps
Max Impact for vector artwork
that's what I learned here and it works for me
High speed is fine depending on the profile you use, print a small version of your artwork at high speed and standard, then compare
Tony Rome
thanks everyone, when i bough this the salesman said not to change anything, and most everything i print looks fine, but now i am wondering what else i should be adjusting, if you want to throw out some suggestions...im all ears...thanks again...huge help!
