Which Switch to use?
Discussion in 'Computer Hardware' started by rcook99, Aug 7, 2018.
  1. rcook99
    rcook99 Very Active Member
    2,138
    3
    38
    May 25, 2006
    NE
    Currently running a Netgear ProSafe GS108 but have run out of room. I currently have an HP ProCurve 1800-24G that was given to me from a friend. Should I use the HP or upgrade the GS108 to a 16 port switch for $50 brand new? Keep in mind I just use them for internet or printer access. Any help in which direction I should go would be appreciated. Thanks,
  2. Solventinkjet
    Solventinkjet DIY Printer Fixing Guide
    3,832
    686
    113
    Aug 2, 2011
    Denver, CO
    In your case you could probably go with anything and it will work for you. If you just need internet and to connect to the printer that is. If you have gigabit internet or want to be able to transfer large files from one computer to another quickly, you want to make sure the switch supports gigabit connections.
  3. rcook99
    2,138
    3
    38
    May 25, 2006
    NE
    Both the Netgear and HP are gigabit switches. I just want to make sure I use the right one as it appears the HP is a managed switch as opposed to the Netgear being an unmanaged switch.
  4. Solventinkjet
    3,832
    686
    113
    Aug 2, 2011
    Denver, CO
    Oh ok. Either should work. Managed just gives you more options to control how things connect and has better monitoring capabilities where as the regular switch simply connects devices.
  5. rcook99
    2,138
    3
    38
    May 25, 2006
    NE
    So even if I utilize the HP switch I won't be subjecting my network to any outside problems being its a managed switch vs the unmanaged switch? Just want to make sure I am doing the right thing. I am actually looking at a new GS116
  6. fuzzy_cam
    fuzzy_cam The Granbury Wrap & Sign Guy
    146
    28
    28
    Mar 7, 2017
    Granbury, TX
    I wouldn't recommend any switch without gigabit speeds. You would want to make sure your computers/file storage devices support gigabit speeds too for faster transfers, but even if they are not the switch should be compatible with lower speeds. I would also recommend going with an unmanaged switch for your setup, just takes a lot out of the equation.
