Who is back-cutting on Gerber?
Tim Aucoin
Is anyone else using the back-cutting feature on the Gerber? I had a hands on lesson from Dana Goodale himself while at ISA in April. He taught me the two methods of back-cutting and I must say they work EXTREMELY WELL! They have saved me hours of time trimming and they make the finished product look extremely professional! :thumb::thumb: I especially love the back slit feature (makes them crack'n'peel decals). I'm sure everyone is doing this and I'm just preaching to the choir, but I've just started doing it since ISA and I'm LOVING IT!!! :Big Laugh:Big Laugh
petepaz
didn't know about this. what gerber are you back cutting on and do you mean you are doing your kiss cut of the label and then you are cutting through the liner for individual pieces?
Tim Aucoin
Can I do this on a 4b?
Forgive my ignorance... what's a 4b?
Here is a link to a PDf on it!
Here is a video on simplest
Here is an other video
The Back Cut Dialogue Box in Omega 4 is definitely the way to go. It makes this an extremely simple process. I went and purchased a second blade holder for my enVision 375 so I don't have to change the depth every time. One is dedicated to front cutting and the other to back-cutting. The only tricky part was getting the pressure just right for back cutting. Once that is figured out, it's simple.
I've made a video of the process that I need to finish editing and I'll post it here once it's complete. :thumb:
Tim Aucoin
Yes... it's a two step process. Do the regular front kiss-cut, then turn it over and to the back cut through the liner as well as the split line (for a crack'n'peel decal) if it is required!
Tim Aucoin
Tim I also bought a second knife holder!
It's very handy to have, isn't it?! It was a no brainer for me, especially since I discovered that I can purchase all of my Gerber parts AND supplies from GMS at less than HALF PRICE over what I was paying my local supplier. That was a great discovery for me! :clapping:
Ditchmiester
Backslit
Have you had any issues with the back-slit for crack n peel vinyl decals not lining up in the center of the part? primarily do squares and rectangles and it always seems that it is pushed to far to the right on my envision 375 cutter. Thanks,
Andrew
Tony Teveris
The back-cutting is really taylored for sprocketed cutters because for the need to flip the job over there are no targets to 'square" the job up. Also, the software controls the knife pressure via cutter commands. As for the IVB it may work but you would manually have to adjust the weights on the knife.
We would try it but believe it or not you can not find a IVB, Sprint anywhere in the company - sad but true.
Malkin
:Oops::Big Laugh
Some time I'll have to see if we can do it on our HS15plus.
Looks interesting, though we don't get much call for that.
