Question Who Makes Adhesive Vinyl With the Longest Shelf Life?
David40
I've mainly used my printer for just about everything, but I needed to make some vinyl lettering for a project, so I grabbed a roll of Oracal 651 and discovered that the backing was basically welded to the vinyl. I tested a couple of other rolls and the same thing with those. I hated to trash all that vinyl. Very wasteful. This makes me curious about the shelf life of adhesive vinyls. Are there brands that have a longer shelf life than others? Do the manufacturers have shelf life recommendations?
MarkSnelling
Yes....most adhesive manufacturers will claim 2 years for shelf life. If it is in a consistent environment, despite the shelf life, the product will still work for many, many years....but in an environment where the temperature and humidity fluctuate, you'll see much shorter lifespans.
tulsagraphics
Today I tried using some 3 year old GF 226 (low tack mural job on some older paint -- thankfully not a low VOC formula), and it was really hanging on to that liner. Print and cut job. (11) 24" tall letters.
Regular high tack tape? Laughable. TransferRite AirMask 510U? Not even close.
Knowing I'd probably have to trash the vinyl... I said eff it and threw down some frickin' 3420 laminate as transfer tape! :roflmao: And... it actually worked!
Of course I don't recommend that method, and it wasn't the quickest install -- had to hold down the first inch or two of each edge as I pulled the laminate away... but at least I salvaged it.
hybriddesign
owner Hybrid Design
GF’s water based adhesive is terrible as it ages. We don’t use a lot of it so we often end up tossing half a roll as it just gets too hard to remove from the liner
