Question Why Outdoor Signs are turning black
Discussion in 'General Chit-Chat' started by CDS PROFESSIONAL SERVICES, Feb 23, 2021.
  1. CDS PROFESSIONAL SERVICES
    CDS PROFESSIONAL SERVICES New Member
    9
    Mar 11, 2017
    Apple Valley, Ca
    Lately I have noticed outdoor lighted signs with translucent signs becoming blackish, like burning out.
    What causes this? Is it no uv protection or the laminate not a uv protector?
  2. Z SIGNS
    Z SIGNS Very Active Member
    1,120
    175
    63
    Feb 14, 2009
    Trenton NJ
    That's what happens to printed signs. They turn brown in a few years.
  3. Billct2
    Billct2 Major Contributor
    7,547
    664
    113
    Mar 12, 2005
    New England
    Either cheap materials which fail earlier or the right materials and they are old.
  4. gabagoo
    gabagoo Major Contributor
    5,776
    114
    63
    Oct 10, 2006
    Vaughan, Ontario
    3ml with 3ml laminate will look like they have a fungal infection attacking them. Not sure how a cast film with laminate fairs....hopefully a few years longer.
  5. Texas_Signmaker
    Texas_Signmaker Very Active Signmaker
    4,927
    1,828
    113
    Oct 21, 2016
    Frisco, TX
    It's why I use cast translucent cut vinyl when I can... I try to at least push a customer to figure out how to make the sign without needing to print...it will only benefit them when we can double/triple the life of the sign.
  6. rjssigns
    rjssigns Major Contributor
    5,221
    554
    113
    Jun 4, 2007
    Home Office
    Vinyl going bad is what makes them look like that.
    Only way to make them last is to paint second surface on clear polycarb then spray translucent white flood coat. Learned that from an old time sign guy I worked with from time to time. He did a lot of backlit work, some of which is still in my neighborhood over 20 years later.
    The rare backlit panel I need gets subbed out now, but it's still second surface on clear with white flood.;)
  7. Val47
    Val47 Boudica@Nite
    320
    92
    28
    Mar 2, 2020
    Spokane, WA
    do you have pictures you could post?
  8. WYLDGFI
    WYLDGFI Merchant Member
    1,552
    277
    83
    Oct 27, 2006
    Linden, NJ
    We like to do that way as well when the client is using clear polycarbonate or similar.
  9. McDonald Signs
    McDonald Signs McDonald Signs & Graphics
    104
    14
    18
    Feb 11, 2013
    Guin, Alabama
    Top layer of Laminate is probably turning brown....
