It is not a "well documented fact" Corel is way easier to use than Illustrator. That's just your opinion, possibly coming from what you're used to using in the workplace. I've known a lot of people who were used to Illustrator or Freehand and totally despised Corel when trying to use it.
Yes, there are some areas where Corel makes it easier to get certain things done. I prefer some of the path editing methods Corel offers since one can build up certain types of objects quickly and precisely. But there are other key areas where Corel comes up short. The zooming and hand panning methods are just one example.
I use the scrollwheel method (on occaision) in CorelDRAW. That still doesn't make up for the fact Corel cannot toggle the hand pan tool on/off like you can with Illustrator and several other graphics apps using the spacebar key. And the scrollwheel method isn't very precise either on zooming.
Although you can "hot key" a number of functions, they still don't behave as they should -with the hand pan tool deficiency being a big problem.
I would invite anyone using CorelDRAW 10, 11 or 12 to show me outline effect quality that equals that of what I showed from the AI CS2 screenshot (or even the Freehand 10 screenshot for that matter). From what I've seen with CorelDRAW 12 (from demos) it behaves the same way -giving you lots of control points to make up for not so great floating point capability in the code.
Techman said:Comparing corel draw 9,,, an old program against an updated CS adobe product is not a valid comparison
