Need Help wild background fill with onyx rip
altereddezignz
I have a file that was created that when i rip that file it fills the artboard with a color?
So i expanded the whole design and resaved it but i still get the same result.
It does not make a difference if the file is an eps or a pdf when ripped. This is the first time i have ever ran into this issue.
First image is the designed image the second image with the colored background is in rip.
Onyx rip
Asuma01
It can in some cases make a big difference if the file is an eps or a pdf. I would try both. If that doesnt work then export it as a tif or jpg.
letterman7
That was going to be my suggestion as well. Try it as a .jpg and see if it still fills. What program are you designing in?
altereddezignz
I have tried both .eps and .pdf. I just tried as a tiff and that seemed to work for fixing the background issue. i am trying to dissect the file now to see if i can figure it out.
altereddezignz
This was created by a customer we print for in illustrator. Never had this issue with any of his other files. I am looking into the file now.
