Will a 36 inch Mutoh Falcon do a contour cut?
Legman
I found a deal on a 36" Mutoh falcon Outdoor and would like to know if this thing will do contour cuts so i can make decals, etc.???
Many thanks for your competent help.
Robert M
Falcon
You will need a vinyl cutter with an optical sensor to complete that package. They start at $1500.00
Jackpine
I am guessing you are referring to a Graphtec CE series......A very good cutter for the money. He won't go wrong with that cutter. Your work flow will be better with a printer and a cutter rather a print/cut in one machine.
bob
No, that's a printer. It prints. For cutting you need a cutter.
If you meant to ask if this machine will print images that can be contour cut, the answer is yes.
Contour cutting is, for the most part, a function of whatever software you're using as well as having a printer and a cutter.
The printer needs no special ability other than printing. It's handy if the cutter has some sort of optical registration mark sensing mechanism but it's not show stopper if it does not.
