WILL VHB tape stick and hold to Brick???
Discussion in 'General Signmaking Topics' started by depps74, Dec 13, 2019.
  1. depps74
    depps74 Guest
    160
    7
    18
    Apr 28, 2016
    ct
    I am mounting 1/2" Ultraboard (gator board) prints to a brick wall. The prints are no more than 36" x 24". Will VHB tape hold them to brick or should I use a cleat? I have the 3M VHB clear jelly like tape, 1/2"
  2. Moze
    Moze Precision Sign Services
    2,033
    156
    63
    Feb 27, 2012
    Dallas, TX
    Short answer, yes - if there's enough surface contact. If it's a rough, uneven brick and the tape is on a bunch of high points without a lot of surface contact, then you would probably have issues.
  3. unclebun
    unclebun Very Active Member
    It will stick, but likely only temporarily. That's been our experience.
    • Like Like x 1
  4. Billct2
    Billct2 Major Contributor
    7,482
    649
    113
    Mar 12, 2005
    New England
    If it's clean, yes. But I would add dabs of lexel or similar
    • Agree Agree x 1
  5. laserfred
    laserfred Member
    You can also apply two layers of 3M tape on top of each other and you'll get a better contact on highly textured surface. We've had good results on cinder blocks.
  6. visual800
    visual800 Very Active Member
    3,928
    267
    83
    Aug 4, 2010
    montgomery, alabama
    I would just do dabs of silicone without even wasting vhb tape tape it up painters tape and let it set up
  7. kcollinsdesign
    kcollinsdesign Active Member
    527
    154
    43
    Apr 22, 2007
    Normal, Illinois
    Use a cleat. Easier to install and will be easier to repair later. Plus a cleat allows for easier removing for cleaning or re-positioning.
  8. Chris Keena
    Chris Keena New Member
    13
    1
    3
    Feb 15, 2019
    NJ
    Which VHB Tape did you have good results with on cinder blocks?
  9. Moze
    2,033
    156
    63
    Feb 27, 2012
    Dallas, TX
    You didn't ask me, but just go with RP45. It's about half the cost of most other VHB's and works great.
  10. Chris Keena
    13
    1
    3
    Feb 15, 2019
    NJ
    I had two picked out, the RP45 and VHB 4658 (removable). The RP45 looks like the more reliable to go on poured concrete that was finished/sealed 14 years ago...
