Window Perf and Laminate
Kilowatt
So in the past if I laminated the window perf it was foggy and couldn't see through I used Oracal 210 laminate. Is there a better laminate to use on window perf that will still allow you to clearly see through?
DIGITAL DESIGNS
From what I believe 210 lam is not optically clear. You would want to use an optically clear lam with perf IMO. We always use Clear Focus perfs and lam.
AGCharlotte
1360Z is what we use here. 8518 is "clear" but it's a little yellowish. been using some off brand PanoRama Protect (since the Avery has been unavailable) lately which has worked fine as well.
