Recently had a customer that wanted to cover a door so he could still see out, but others can't really see mess inside a store room.
We decided on trying 70/30 perf with optically clear laminate.
He also decided to leave the perf unprinted and white.
You could still see through it from both sides plain as day.
It was a clear glass door (no tinting), the room inside is pretty brightly lit, and the hallway outside the door is probably a little darker which didn't help.
So I put some regular laminate on the inside of the door to fog things up.
As it ended up, he just wanted to be able to tell if someone was standing outside before opening the door into them.
Another customer in the same building want's the same thing, except he wants it to be truly one way vision.
He needs to have good vision looking out, but pretty much no vision looking in.
This customer wants a full color print, and I'm wondering if this will help viewers tune into the print versus seeing through the film?
Thank you,
Tony
Thank you,
Tony
