Window Perf Help
speedys
I've been reviewing posts on here and haven't found any that pertain to my particular problem. I have a 54" printer and have a 77" window to put window perf in. The design is split so that the upper 2/3 of the window is lighter with logo/design. THe bottom 1/3 is black with writing. All on window perf. My question is: Do you "Butt" the 2 pieces up together? Tape? Just use Primer? or do you overlap? I am assuming no on the overlap, but thought I would mention it anyway...Any advice is greatly appreciated.
Thank you!
sign_student
Overlap
Hi there,
Our installers here always overlap. I was told that the problem with butting it is that the vinyl has a memory and eventually you will end up with a small opening between the pieces
Hope that helps.
-Patrick
dwt
You will still see the seam either way, but from my bar stool they will look the same.
Malkin
ah.. ok. That would be better for perf I think as well.
overlapping seams are very noticeable from the inside.
