d fleming
Our heat index today calls for 109 degreesAlthough I might consider wet application on a hot window in the sun, I have never found a need for installing perf vinyl wet.
Havent' heard of that stuff, I'll look into it, thanks!I've been spraying mine with NAPA 8887 Cut-In Clear. Works well.
We overlam all ours. Whether it's solvent or latex or uv...the ink type doesn't matter, most places tend to use industrial cleaners to clean their windows.... Last thing you want is a big smear because someone's using a strong chemical that'll erase graphics.
If this is your first time doing window perf it might seem scary.... But it's easier than vinyl. The hardest part about any install is alignment... And if you can install and align SAV then you can do it with window perf.
If you laminate... Use an optically clear overlam as was already mentioned. Overlam helps it not rip.... But it's still easier than vinyl, so if you reposition and have to lift the vinyl up... be careful.
If you don't.... If you have to lift the vinyl due to a wrinkle or to reposition it.... Be very careful, window perf rips easy.
Which window perf are you using? A lot of perf stays up for a few months only so many brands release crappy perf that's rated for 6 months. It's cheap and we use it a lot for temp graphics.. But if it's longterm make sure to get a decent brand that's rated for longer. 3M is rated for 4-5 years I believe... It's like triple the price of the cheap stuff, but worth it for longevity. I'm sure Avery has a long term option as well.
What works for me when doing window perf...
I use the "Bill Collector" squeegee from Fellers.
Start by cutting the backing paper off 12" from the top of the roll. Visually line up the panel with the top of the window and use the squeegee to apply from where you cut the baking paper, and work to the top. Go down and make sure the panel will track correctly. Then roll it up and pull the backing off and apply like normal. Usually I do left to right motions using VERY LIGHT PRESSURE for the first 1/3 or 1/2 of the panel. The reason I use light pressure is because that stuff can stretch easily in the summer and create wrinkles. I usually get about half way down the panel before I feel the need to squeegee down instead of side to side to prevent wrinkles... still using light pressure in the summer time. Then go back and use firm pressure when everything is mounted.
It's way easier to install on a window if it's cut to size before approaching the window. Make it so that it will get to within 1/8"-1/4" of the edge, being careful of the rubber gasket material.
As far as edge seal, we have never needed it. My personal vehicle has had a perf wrap on the back window for over 2 years that looks perfect and has no edge lifting. Only blemish is where we hit it with a piece of MaxMetal when loading a 4x8 into the bed.
Lots of great info here, thank you. The window perf will probably be changed out after 1 year, the customer likes to change specials and prices on his marketing, so I don't expect it to stay up any longer than 1 year. I went with Kapko/Star brand 60/4, and am using it on my HP latex printer. The Kapko is the house brand for my distributor. My customer mainly wants the window perf for shade on the interior because it's a new construction site and there aren't any shade trees close enough. I probably won't overlam it since they'll probably change it out after 1 year. Also, with this graphic, there will be no overlay/seams needed for alignment, I can print each window in one section with my 54" printer. However, I hear different suggestions whether or not to add bleed and trim afterwards, or short cut the vinyl about 1/4" from the window frame...what are your thoughts? As long as I make sure the measurements of the window are exact, and the install is perfectly straight, do I need bleed? Common sense tells me that installing on a window with a frame makes it harder, since there's no good placement to put the tape to hold everything in place, especially if a frame is in the way. Thoughts?
I'll be very careful and slow when installing, since it's my first time using this stuff, and fear of the vinyl ripping. But most everyone here says it's cake to install if you have experience with vinyl and squeegees. I wet mount, dry mount, 2nd surface mount stuff all the time on aluminum, ACM, coroplast, plexiglass, and styrene for the past 3 years, so hopefully I've got enough experience to handle the job. It's my dumb-no-common-sense-lets-hurry-up-my-arms-are-tired assistant that worries me. I'd be better off if I grab my husband and kids (who follow direction) help me out with the install. They helped me install a 12' tall X 30' wide wall graphic last year and did great. lol.
Thanks again for al the tips.
