scott pagan
Steve Gibson has a "Never10" option. https://www.grc.com/never10.htm more tips here http://www.pcworld.com/article/3048...solutely-positively-dont-want-windows-10.html
Well, you still have that paying scheme if you don't have a qualifying computer to "upgrade".
I actually wouldn't have a problem with buying the OS (I prefer fresh installs to upgrades like this anyway, I've never had a good turnout upgrading a Win OS via this method), if I was able to not have to deal with some of MS product interconnectivity that they try to peddle(force) on to you.
The frustrating part is is that if you were to strip away how they conducted the rollout and the telemetry aspect of it, from a usability stand point it isn't a bad OS. It really isn't. They are behind the times on some aspects of it (virtual desktops) compared to other OSs, but it really isn't all that bad, if it wasn't for those 2 aspects. At least in my mind.
THIS FREE VERSION...........the d/l, is ONLY AN UPGRADEABLE version.
33 days of running Win 10 and it let me roll back to Win 7 without a hitch...so far.
Welcome back, baby...it's been a long time.
JB
Did you just revert back or did you remove all the other remnants as well?
I'm not sure. How do I check for any remnants?
JB
If I recall correctly, this $Windows.~BT is what you are going to want to look for. Make sure you have your show hidden files/folders on and look for that in your C drive. See how big that is.
I think the easiest way of deleting it first is going to be to run that GWX program that most talk about and turn everything off and then go to delete it. If you do it manually, you'll need to block the installer, because they do have it setup as a trusted installer.
I would also turn off auto updates. Even if using GWX, there is nothing to prevent MS to using a different KB package to install everything once again and we will be looking at the same situation. You would then have to get a current version of GWX and/or Never10 I would imagine that would deal with the old and new KB packages.
The irony is, if they want to get you, more then likely they will, especially if you still try to take advantage of the update support until your particular OS goes EOL. Even though Win 7 and Win 8 are "officially" supported until 2020 and 2023 respectively, you can't really take advantage of the updates unless you want to have to be dealing with this all the time. Of course, the thing that you have to worry about really, is how long are software companies still going to write for 7 and/or 8, especially if a lot of people have already migrated to 10?
GWX gives you a number of options to continue to get updates but not Win10 updates, or no updates etc... It also has a desktop monitor and I think keeps itself updated...
