Windows 7 sp300v driver issues
Discussion in 'Newbie Forum' started by brianp77, Jun 24, 2012.
  1. brianp77
    brianp77 New Member
    1
    Feb 13, 2012
    Weslaco TX
    Just bought a new laptop with Win 7. Having issues installing the usb driver for Roland SP300-V. Win 7 is Home Premium and I understand driver may only work with Win 7 PRO. Thanks for any help.
  2. Scott Reynolds
    Scott Reynolds Active Member
    828
    32 bit driver?
  3. john1
    john1 Guest
    Do you have the option to take the laptop back and get one with PRO on it? I know Best Buy took away their restocking fees and all and Walmart doesn't have any also if one of those places is where you got it at.
  4. noregrets
    noregrets Member
    355
    Jan 27, 2007
    Nz
    Mine works on 32bit Home Premium...... It wasn't easy to get it working however. I can't recall what I did to get it going in the end, but persevere with it a bit and see what happens.
    Try uninstalling/reinstalling the driver and make sure you set up the port correctly
  5. noregrets
    noregrets Member
    355
    Jan 27, 2007
    Nz
    by port, I mean the usb port. Mine is on USB008 Virtual Printer port for USB. It might be worth also checking the printer in each of your usb's once it is installed and see if it is recognised
