Winging it!
mrchips
Just finished this. All eastern white pine, 5/4x52" long. Stained black with 5 coats of poly.
The bird is 5/4 thick and 10" high. All hand carved....no sanding and stained with stains that I make and coated with poly. It is mounted off the ground with stainless steel screws.
Thanks,
Joe, Makin Chip$ and Havin Fun!
Outstanding !!
Is the bird connected from behind with screws or do you just rely on good glues.
I would imagine you pegged it or biscuit jointed it with glue, but I was just wondering ??
mrchips
Thanks everyone!
Gino, the bird is attached with 2 stainless steel screws from the back.....no glue.
When it needs re-coating, the bird can be easily removed to make the process simple.
Joe,
GAC05
Quit buggin' me
Detail work is over the top, looks like something I would want to keep inside out of the weather.
Thanks for posting up an example of a real sign.
wayne k
guam usa
