Click to Support Signs101 ...
Awesome link! Thanks is just what I need.
Have you used this? Is this the same material they make self healing mats out of?
I wonder if after a couple of years of use, when it is cut-up, if you can just mix up enough
to recoat and fill in the cut marks?
Yes they were built with all 2" tubing. For the casters we got threaded casters and welded a plate to the bottom of the tube with a long nut or coupling nut welded in the center of it. Also something I learned in the process was to use "total locking casters" these not only lock the wheel but also the swivel.
We had been using Rhino mats but when I needed two more I couldn't find anyone with them locally.
So instead bought two of these clear mats from Yello Tools. http://yellotools.us/Cutting/Cutting-Mats/
They seem to be lasting well but the plastic is a bit stickier than the Rhino.
we have found that PVC is a great table surface, comes in 48 x 120 sheets make sure you get a minimum of 12mm so you can use both sides of the material
