If it's going to be a high traffic area, you can always put paint protection film over top of the laminated vinyl in key areas or cover the whole thing. Cleaning the doors very well and using an adhesion promoter (like 3M primer 94 - for 3M vinyls only) and then an edge sealer pen will also help with edges lifting.We have wrapped a few exterior doors. The life expectancy really depends on how high traffic it is and what type of traffic. We recently wrapped a coffee shops doors (Tim Hortons) with 180 and they were coming up in about a month. There were gouges in the vinyl and a lot of the edges were coming up. I went and had a coffee and watched people walking through the doors. While they had their hands full they were opening the doors with their feet and hips which was rubbing the vinyl from the edge. They also had keys and whatnot in their hands and would scrape and gouge the vinyl. If it is a high traffic area I wouldn't recommend wrapping the doors at all.
What's the advice you're looking for?I would like some advice on interior doors. As it turns out, you need a separate designer to do that, ridiculous. I used to think that you get a house that needs finishing, you hire a designer, and he takes care of everything, starting with the walls and ending with furniture. As it turns out, it's not that simple. There is a separate designer for every part of the apartment. So basically, you overpay for someone who will mix expensive furniture in a render and make it look good. Long story short, I bought the interior doors from doordesignlab.com.
I didn't notice the links. I was wondering why they bumped a thread they didn't read. Now I see this "member" is a bot.it's probably spam trying to create backlinking to that website to lend it credibility
