Wrapping Question - Self Sticking!
Discussion in 'Tips & Tricks' started by mameighan, Aug 19, 2013.
  1. mameighan
    mameighan Member
    242
    5
    18
    Jul 18, 2007
    Moberly
    Generally, I have done mostly decals and some window signage but have uses thicker vinyl than the 2mil recommended for wrapping.
    My question is this. I have watched lots of videos on wrapping and it is done in large pieces and the installers are moving it around pretty easily. What are the tricks or how do you stop the piece from sticking to itself or falling back on itself and ruining the piece?
  2. MikePro
    MikePro Major Contributor
    5,003
    245
    63
    Feb 3, 2010
    Racine, WI
    handle it like you would a paper towel, that's dripping-wet.
    and then if it folds over on itself, take the time to peel it apart.... with a good portion of the graphic already adhered to your surface, as to give you the ability to only hold-on to a portion of the graphic while working out the "flop". good wrapping vinyl won't completely bond to itself right away, and will still adhere to a surface when pulled-apart from itself. any wrinkles as a result of folding/stretching, will come out with a bit of heat (especially if heated prior to application)
  3. mameighan
    mameighan Member
    242
    5
    18
    Jul 18, 2007
    Moberly
    Thanks - I was what I was hoping to hear that it wouldn't just immediately stick to itself. Seems like it has quite a bit of pliability especially with added heat
