I would rather stay away from any plastics but it's always a hit or miss. I wrapped a dodge caravan two days ago. 3M was sticking on the rubber window seals like crazy. I startet to wrap them up because why not, then the last rubber piece was not sticky. I had NO idea why. I ended up ripping off the other pieces.
Avery came out with a new material that is actually made for plastics. Its called 1106 HT ( hi tack)
You can try that. It is expensive compared to 1105 and to be honest with you the tackiness was super super similar to 3m ij180cv3.
The reason I don't like adhesive promoters on plastic because eventually it needs to come off. You will ruin all plastics with any glue remover chemical.
