X6, Text is missing from saved file
J
john1
Guest
I designed a brochure the other day and i go to open it up today and it's all right minus the text. The text boxes are there because when i click on them it shows up like normal but you off click aka deselect the text box and it disappears.
Saving as a pdf shows blank areas where the text should be.
The original and back up file is like this. Any ideas why?
J
john1
Guest
No idea to be honest. Other files i designed open up just fine. Arrrr
Is the font that is causing the problem in this particular file a postscript font? If so, simply uninstall the Windows Update referenced above and you should be good to go.
