XC-540 Media Walking
orange10
We have a XC-540 with very low hours. It prints great and cuts great but the media will walk about a 1/4+" every 2.5hours. We have brand new media flanges however we dont have the locks. Also I feel the pinch rollers are in great shape... We are still fairly new in the vinyl printing industry. Is this the norm? We are running long production runs print/cut and would like to make it as low maintenance as possible.
J
john1
Guest
for some reason on my Roland sp300i i get the same sometimes. I use all the pinch rollers and it doesn't seem to change. I guess sometimes you load it good, sometimes it's off a cat hair
orange10
Yes I always use all the pinch rollers. Is there a more precise way to make sure the media is loaded straight?
cdiesel
Make sure the media roll is tight on the core, the flanges are in the core all the way and evenly, and the flanges are on the bottom rollers evenly. Pull the media through the machine, gently pulling on the center of the roll and then lower the pinch rollers. There will be times when it's just off. Not much you can do about it.
DRamm76
It also has a lot to do with the media itself. Even in the case of cut vinyl, 50yd rolls rarely cause tracking issues because they are wound tight from right out of the box where as 10yd rolls cut down by the distirbutor are often rolled out by hand so they are never as tightly wound as once before.
Also, check the grit rollers. Some times build up underneath them can cause the media to shift if it's not properly removed.
