Melanie Barothy
Hi guys I have a Roland XC-540 need some assistance, have had to replace several heads in the last year and a half. Last issue began when shades of blues were off then I discovered half of the light cyan head wasn't firing. I then replaced dampers, check lines and even soaked the head to no avail. Still was able to print with light cyan half firing. During the same time the quality of the black head started to deteriorate. Any black text would start to become blurry and not print clean, after 6 months the light cyan failed completely and shortly the black head failed. I replace all print cables and new heads. New heads install and new cables with dampers and then this new issue presented itself. The yellow and blue cyan head now seems to print with bands of ink over anything I print. I have reseated all the cables to make make sure none of the pins are bent or damage and they are all new cables but still no luck. Not sure what to do now as calling for a tech isn't easy being that my printer is outside of the US. Any help will be gladly appreciated.
