Everything is set up. The plasma table is ready to cut the frame pieces. Then I'll clean, prime and paint them or perhaps take it to a powder coating place and be done with it.
The 20# HDU precision board is here. I have to tweak the cut file a bit but essentially I am ready to go.
Then, like a complete klutz, I tripped over the air hose and yanked the pressure regulator off of the compressor.
So now I'm off to get a new one. If the gods smile uopn me, I should have the frame together by tomorrow afternoon!
You have probably already painted your
signs by now, but if you have not, this may help in the future. For Precision Board and SignFoam
signs I always prime them with FSB-88. It's a water based primer filler that is extremely thick in the can so that it can be applied with a squeegee on some surfaces. It is made by Coastal Industries specifically for SignFoam, but works on all HDU
signs like this, you'd thin it and brush or spray it on. I buy it from TubeLite You need to make sure it doesn't puddle around the edges or it will crack when it dries. The FSB-88 fills all of the open cells in the HDU and makes for a very smooth surface that makes your paint job look smoother. If you don't get it primed correctly, you can end up with a flat painted surface even if you use a gloss paint (I know from experience when I've run out and tried substituting). I have never had a
sign peel and have used both water and oil based paints on the
signs. In general, I typically paint the background with a flat or satin water based paint depending on the location of the
sign and then use a gloss oil based enamel on the raised face. The difference in finish helps with visibility of the
sign in my opinion.
Also, earlier in the thread, I read where someone said that they had an issue with paint peeling off of PVC. This can be solved for by wiping the PVC down with Acetone before painting it. It will break the surface and allow the paint to bite very well. Don't soak it, the Acetone will melt or warp your PVC, just wipe it down. you'll see a white haze as it breaks the surface. I just use a damp
paper towel and have done so for many years and have yet to see one of my PVC
signs peeling or the paint scratched off.
