Yellow to Black Gradient has a red in it?
Discussion in 'Designs & Layouts' started by duggan, Jul 13, 2010.
  1. duggan
    duggan Member
    35
    I'm designing a vehicle wrap, and the bottom of the truck it has a yellow to black gradient fade. Looks good on the screen, but when I printed my test page, it has a redish/orangish band in the print.
    Any suggestions?
  2. mikey-Oh
    mikey-Oh Very Active Member
    1,431
    1
    36
    Apr 16, 2009
    okc
    you might try a black to transparent fade over a solid yellow element. but it will probably yield the same result
  3. 3dsignco
    3dsignco Active Member
    949
    1
    Try applying the Fade in Photoshop. Sometimes fades created in Vector Programs cause Strange Things when ripped.
    If you did it and PS and still getting you need to check your Calibration, Profiles.
  4. jc1cell
    jc1cell Active Member
    596
    Jun 11, 2007
    76137
    See if this helps. If you're working in CMYK check the color combination used, then apply the same to the 100k black. I use this technique a lot, as well as mikey-Oh's technique.
    Cheers,
    jc
