Yeti Cooler Template
I just took measurements of all sides except the bottom, added in the extra depth for where the top overlaps and added an extra 1/2" for the lip of the lid.
I used Arlon DPF 8000 (the same as I use on snowmobiles & ATVs) The only issue I had is it stuck almost too well.
nitro2010
Randy
I have wrapped them before, I am just looking for a template for the Tundra 75 & 160 so I can design, print & cut material and wrap them.
caribmike
Retired with a Side Hustle
i just got done wrapping 6 yeti coolers using polar grip. awesome stuff
I have a customer in the Porta Pottie business and cant seem to find an adhesive vinyl that will stick to the weird plastic these outhouses are made from.
Would Polar Grip work on that type of plastic in a hot Caribbean environment?
Geneva Olson
Expert Storyteller
the lid of the yeti is textured and it stuck well. order a sample and see if it will stick. the brand is drytac. polar grip is the line.
