Font Issues in Composer 4
FSDesigner
I have been having a problem with using Arial Black in Composer. Both Arial Black and Arial Black Italic are coming up italic. I can't figure out how to delete a font in composer so I can convert it again. Has this been a problem for anyone else?
Thanks in advance!:banghead:
Fred Weiss
Never had the problem but here's how to find the file name of the font ...
attachment.php
Select the second text entry tool and click in your workspace.
attachment.php
Click on the Font button to bring up the Font Select dialog.
attachment.php
Select the font from the drop down menu and then click on the View Font button.
attachment.php
The font file name is shown at the top of the Font View window.
attachment.php
Go to the GSPFonts folder to locate and delete the font.
FSDesigner
So, I found where the .gsp fonts were, deleted ARIAL BLACK and tried to re-convert it with my GSP converter and it's wanting to put it back in as italic. I attached a screenshot of what my converter looks like... the first preview looks normal but when I click convert it is italic!
Fred Weiss
Never had it happen. As I understand the TTF Converter, it is simply converting to GSF format the glyphs that are there.
What happens if you convert the Arial Black italic version? Is it also italic?
You might want to try uninstalling the Arial Black Italic version from your Windows fonts and also double clicking the Roman version to see if it is correct. If it is, try converting it again without the Italic version being there to interfere.
Tony Teveris
I just noticed that on my Windows 8.1 in the Fonts folder a user can "hide" a font or any version (Bold, italic, etc) of a font. I wonder if that has anything to do with the conversion or reading the font file.
I know within the Composer "small text" font selection dialog the user will NOT see any "hidden" fonts, TTF Converter shows all the fonts but maybe there is an issue reading a "hidden".
T
