Need Help Install instruction for Summa F1612 Carriage board?
White Haus
Not a Newbie
Does anyone happen to have install instructions for Carriage board replacement on a F1612?
We blew our slot 3 a few months ago and now just blew slot 2. I have the board and the "instructions" that came with it are just a QR code that leads me to a dead end on a Summa website.
Can anyone help?
I'm going to need to replace this thing first thing Monday morning as we're dead in the water in the middle of a few large projects that have to be cut on the F-series.
Thanks in advance!
cornholio
Here you go...
  • 2104_FSERIES_Summa F Series carriage board new revision (KIT-5003) - F series firmware MD9974 ...pdf
Shenzhen Oyea
TOM ZUND – TORIELLI ELITRON COMELZ ESKO TALAMONTI
Technical Specifications
Model
F1612
2350mmx1940mmx1100 mm(without roll support)
925°×763°×43.3′(without roll support)
Acceleration
Upto 1G
Maximum Allowed Forces
3 Phase 230V or 3 Phase 400V+N
Repeatability
Within+/-0.05mm on plots
Accuracy
0.05%of move or 0.05mm whichever is greater
Speed
Up to 1000mm/sec(39.4″/sec)
Standard Solution includes
F Series Flatbed Cutter
Vacuum Pack:(1.3Kw pump,Sound Absorber,
Switching Valve)
Safety Pack:(Four Pole Laser Beam Systems)
Camera System
Axis Control Software
Remote Controller with charger and USB Bluetooth Drag Module
Optional Modules/Upgrades
Tangential Module
Router Module
Optional tools Kiss Cutting Tool
V Cut Tool-O
V Cut Tool-15°
V Cut Tool-22.5°
V Cut Tool-30
V Cut Tool-45°
Single Edge Cutout Tool
Double Edge Cutout Tool
Heavy Duty Cutout Tool
Creasing Tool D25 R3 W8 H7
Creasing Tool D25 R1.5 W8 H5.5
Creasing Tool D25 R1.5W1.5 H1.5
Creasing Tool D15 R0.35 W0.7-2PT
Creasing Tool D151PTH1.5
Electronic Oscillating Tool
Pneumatic Oscillating Tool
Consumables for Pneumatic Oscillating Tool
500-9830 POT Knife Flat Point L20T0.63
500-9831 POT Knife Flat Point L27 T0.63
500-9832 POT Knife Flat Point L20T1.5
800-9833 POT Knife Flat S Edge L27 T0.63
Consumables for Routing system
500-9850 Routing Bits D3/3L60/101FIUC(3x)
500-9851 Routing Bits D3/3L60/201FIUC (3x)
500-9852 Routing Bits D3/3L50/121FIUC(3x)
500-9853 Routing Bits D3/3L70/301FIUC(3x)
500-0241 3mm Collet for 1050 FME
500-0242 4mm Collet for 1050 FME
500-0243 6mm Collet for 1050 FME
500-0244 8mm Collet for 1050 FME
500-9332 Vacuum Cleaner Bag
Modules
500-9300 Drag Module
500-9310 Tangential Module
500-9330 Router System
Tools
500-9311 Kiss Cutting Tool
500-9312 Single Edge Cutout Tool
500-9313 Double Edge Cutout fool
500-9314 Double Edge Cutout fool
500-9325 Heavy Duty Cutout Tool
500-9326 Creasing Tool D25 R3 W8
500-9327 Creasing Tool D25 R1.5 W8
500-9328 Creasining ToolD2152Rp1t.5W1.5
500-9329 Creasing Tool D151pt
500-9340 VCut Tool-0
500-9341 V( Cut Tool-15°
500-9342 V(Cut’Tool-22.5
500-9343 V(Cut Too
500-9344 V Cut Tool-45°
500-9320 Electronic Oscillating Tool
500-9350 Pneumatic Oscillating Tool
order codes -consumables
Consumables for Tangential Module
390-534 Standard Tangential Knife-36°
390-550 Sandblast Tangential Knife-60
390-551 Double Tip Tangential Knife-36°
500-9826 V Cut Blade -Hard Metal
500-3303 Gliding Disc Single Sided Knife
500-3315 Gliding Disc Double Sided Knife
390-560 Tangential Knife 45°Wedge 25°
390-553 Knife Install Tool
395-348 Nose Piece for 36°
500-9801 Single Edge Cutout Knife-65°
500-9802 Double Edge Cutout Knife-50°
500-9803 Double Edge Cutout Knife -60
500-9807 Heavy Duty Cutout Knife-45°/90°
500-9825 V Cut Blade-0.9mm
Consumables for Electronic Oscillating Tool (EOT)
500-3313 Knife Guide for EOT
500-9800 Knife for EOTL25-65°
500-9810 Knife for EOTL25-65°/80°
500-9811 Knife for EOT L25-65°/85°
500-9815 Knife for EOT L33-45°/85°
500-9812 Knife for EOT L28-65/85°
500-9813 Knife for EOTL25-0-/65°
500-9814 Knife for EOTL38-45/86°
Consumables for Drag Module
391-332 Drag Knife Holder for 36°&r60
391-360 Standard Drag Knives-36°(5x)
391-231 Drag Knife-60°
MPO68K 395-430/395-431 Fibre Tip Pens-Black Roller Ball Pens-Black/Blue
395-434 Pen Holders
https://www.china-oyea.com/index.php?id=3235
Montriaap160
Hi everyone, I just wondering about the carriage board of F1612 can use on F1330 or not? Looking through the physical board is similar on both but the different is the number. If everyone know, please let me know. Thank you
