Picking handles in X5
letterman7
I've been trying to edit a graphic using the nodes around the form. I can pick the individual nodes, add and subtract nodes, but I can't for the life of me grab any of the arrow "handles" to fine tune the line. I'm working in Win7 if that makes any difference. Is it me or something with the program??
Rick
signage
Try restarting Corel while holding the F8 key, this will reset corel to its default settings. If you have customized you work space it will be lost, so I hope you saved it.
Roto
You only get handles if the line is a curve.
Right click on the line and convert to curves... see if that works.
Roto
letterman7
Guess I should have followed up... yes, the lines were curves. I tried restarting per Signage' instruction and still had the same issue. I think I need to fine-tune the pick tool to smaller increments - if I zoomed in close to the section I was working on, I was able to pick the handles a little easier. Sometimes :)
Roto
Try making you handles larger see attachment as you can see I have mine set to medium.
You will find all this under Options "Ctrl J" Edit.
Roto
letterman7
Roto
Ooohh.... didn't know you could do that! Definitely a to-do item. Thanks!
