Need Help 1324x which damper correspond to which nozzle check?
Keevan
Ok so you guys familiar with the nozzle check pattern and the damper configuration. See attached image.
Which damper corresponds to which printed pattern on the nozzle check?
Keevan
I found it, here it is. Now you know when nozzle check bad which damper to check.
Umca
Mistake on the picture. It describes "Top of printhead" But alignment correct for top of dampers. For printhead correct will be opposite top and bottom row. Because the damper has a cross way for ink channel.
Keevan
You are right! but for the purpose of the nozzle check and identifying which damper at fault it is accurate as indicated. I had a bad nozzle test on H as shown in the nozzle check. When I changed the F/H damper the problem was resolved.
