2-sided banner print?
BobCap
Print one side leaving extra substrate on both ends.
Wait untill it dries.
Flip it over, line up the start, print second side.
Done.
I'm not being a smart ***. I do it that way all the time...
Bob Cap
AAI
Gilbert, MN
Mosh
print two banners...way easier, and the time you save from messing up two or three will far outweigh the extra banner material for the second banner. BTW, two sided banners require blockout material...so unless you have some of that printing on both sides of normal 14oz material will look horrible...
2B
Done.
Bob Cap
AAI
Gilbert, MN
make sure of this, otherwise a royal PITA
michsanford
Done.
Bob Cap
AAI
Gilbert, MN
Too funny!!!!
I am trying now...we shall see!!!!!!!!!
michsanford
Yep!!! It worked perfectly, except for the blockout part....
now I know! Thanks,
CanuckSigns
I'm printing one as I type this, here is the easiest way possible:
-print side 1 with "Margin Marks" in the corners at 0,0 offset
-let it dry a few hours
-take a thumbtack and poke a hole through the banner in corners of the 4 margin marks
- load back into the machine with the blank side up
-advance the media untill the tip if the plotter knife is directly over the first pin hole you made, set this exact location as your basepoint
-move the plotter knife over to the second pin mark and make sure it lines up and you are loaded into the machine nice and square
-print second side
all in it takes about 5 minutes and looks so much nicer than taping 2 separate banners together.
2B
-print second side
NICE, thought we were the only ones who used the thumbtack trick
nashvillesigns
Making America great, one sign at a time.
I USE A SHARPIE and mark the edge on both sides where i want to line up on the printer. i use the printer edge, usually, and works good!
LarryB
-print second side
Thanks for the tip. Any tips on rolling it up? Ink on ink is not too good with Roland.
LA Cameras
What I do is advance my material out to the front edge of the printer (exactly 7.5"), use the media clamps as guides for the sides and line them up so outer edge lines up to the outer edge of the material.
When I flip the material, I just line everything up again and if all is right with the world it should be square, no messing with pins and holes.
Of course build bleed into the print as it does skew or shift at times.
