michsanford
Is there a (easy
) way to print a 2- sided banner on my roland sp540?
Print one side leaving extra substrate on both ends.
Wait untill it dries.
Flip it over, line up the start, print second side.
Done.
I'm not being a smart ***. I do it that way all the time...
Bob Cap
AAI
Gilbert, MN
Too funny!!!!Print one side leaving extra substrate on both ends.
Done.
Bob Cap
AAI
Gilbert, MN
Yep!!! It worked perfectly, except for the blockout part....print two banners...way easier, and the time you save from messing up two or three will far outweigh the extra banner material for the second banner. BTW, two sided banners require blockout material...so unless you have some of that printing on both sides of normal 14oz material will look horrible...
I'm printing one as I type this, here is the easiest way possible:
-print side 1 with "Margin Marks" in the corners at 0,0 offset
-let it dry a few hours
-take a thumbtack and poke a hole through the banner in corners of the 4 margin marks
- load back into the machine with the blank side up
-advance the media untill the tip if the plotter knife is directly over the first pin hole you made, set this exact location as your basepoint
-move the plotter knife over to the second pin mark and make sure it lines up and you are loaded into the machine nice and square
-print second side
all in it takes about 5 minutes and looks so much nicer than taping 2 separate banners together.
NICE, thought we were the only ones who used the thumbtack trick
-print second side
