GUIDELINES FOR THE USE OF PHOTO OBJECTS AND PHOTOGRAPHIC IMAGES
This product contain numerous photo images (collectively referred to as the -Images") which are either owned by MR Moebes & Ratajczak OHG or licensed from a third- or a fourth-party. As a user of this product you are free to use, modify and publish the Images as you wish subject to the restrictions set out below. If you are uncertain as to whether your intended use is in compliance with the Guidelines set out below, we recommend that you seek the advice of your own lawyer or legal counsel. MR Moebes & Ratajczak OHG nor ist resellers or suppliers will not provide you with an opinion as to whether your use is in compliance with these Guidelines.
A. YOU MAY, subject to any restrictions set out below:
incorporate any Image(s) into your own original work and publish, display and distribute your work in any media. You may not, however, resell, sublicense or otherwise make available the Image(s) for use or distribution separately or detached from a product or web page. For example, the Image(s) may be used as part of a web page design, but may not be made available for downloading separately or in a format designed or intended for permanent storage or re-use by others. Similarly, clients may be provided with copies of the Image(s) (including digital files) as an integral part of a work product, but may not be provided with the Image(s) or permitted to use the Image(s) separately or as part of any other product; make one (1) copy of the Image(s) for backup or archival purposes.
B. YOU MAY NOT
create scandalous, obscene, defamatory or immoral works using the Image(s) nor use the Image(s) for any other purpose which is prohibited by law; use or permit the use of the Image(s) or any part thereof as a trademark or service mark, or claim any proprietary rights of any sort in the Image(s) or any part thereof; use the Image(s) in electronic format, on-line or in multimedia applications unless the Image(s) are incorporated for viewing purposes only and no permission is given to download and/or save the Image(s) for any reason. rent, lease, sublicense or lend the Image(s), or a copy thereof, to another person or legal entity. You may, however, transfer all your license to use the Image(s) to another person or legal entity, provided that (i) you transfer the Image(s) and this License, including all copies (except copies incorporated into your work product as permitted under this License), to such person or entity, (ii) that you retain no copies, including copies stored on a computer or other storage device, and (iii) the receiving party agrees to be bound by the terms and conditions of this License; use any Image(s) except as expressly permitted by this License.
