3 month Box Truck Graphics
SDSignGuy
Got a job where a box truck will be used as a mobile billboard. The contracts would last up to 3 months and then the graphics will be removed/replaced with new ads. My question is what is a good cheap material and lamination that would really last the allotted time frame without too much degrade and without having to put up control tac that will kill the margin. Thanks for your input.
if its only going up for 3 months max then you can get cheap cal material which is rated for 3-4 years out doors but, is real cheap, same with cheap lam.
Christian @ 2CT Media
Skip the wrap and build a rail mount system and use banner.... I outfitted my former employers box trucks with a rail system and sliding mounts for less than $200, and then printed a banner for each side. All-in-all total cost was ~$600 initially then $350 every change out.
njshorts
Banner is a good idea, also busmark or solvex unlaminated... Banner is a bit expensive overall, but looks better.
If you need some ideas or wholesale quotes, feel free to send us a message.
shakey0818
got any picts
The downside to truckads is they aren't cost effective. $500 for a single side frame kit and $300 for prints per side just doesn't make sense for small companies with many graphic change outs.
gnemmas
If you client might drive the truck, Do Not use "bannertrack".
Use these frame instead. Cost about $6 a linear foot.
ucmj22
the two vinyls i named earlier are only about .30 a square unlaminated, and are meant for short term wraps.
But you have hours of labor to factor for every removal and installation, you can get banner material for $0.20 sq ft and remove/replace in 20mins or less.
MrDesignGuy
:thumb: +1
