33 metre banner rolls....NOT!!!!
Discussion in 'General Signmaking Topics' started by gabagoo, Jun 9, 2010.
  1. gabagoo
    gabagoo Major Contributor
    5,723
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    I have to print 25 12' banners. I buy 33 (108.9') metre rolls (or so they say) and even with 2" or 3" gaps between the banners I can just fit 8 and I am all out of banner material.
    It is one of the few times I have actually had a chance to see if a roll is what they say....NOT!!!
    Oh wait!!! my 8th banner just got a "no media message and I still have an inch or 3 to go.
    Can you believe that?
    I should have an extra 8 feet at this point easily. This is the second roll I have run and the first finished with barely 4" left to go.
    I am definately pro rating the price and altering the invoice for this distributor. Dumb Azzes
  2. Circleville Signs
    Circleville Signs Very Active Member
    2,140
    11
    38
    Sep 30, 2009
    Circleville, OH
    I wonder how much extra cash they've pocketed over the years doing that? Because you know they know that most people will never know EXACTLY how much is on a roll.
  3. signcrafters london
    signcrafters london Very Active Member
    1,186
    5
    38
    May 22, 2010
    London KY
    A local supplier used to do me that way with vinyl all the time. Then he started competing against his customers by making signs as well.
  4. THull
    THull New Member
    22
    Jan 21, 2008
    It may be short...it happens. But you may also want to measure out your banners to be sure it isn't a calibration error. We have been asked that before when a roll came up short. Thats quite a bit short for a calibration error, but they will ask.
  5. gabagoo
    5,723
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    your math is wrong 8 banners is 96' gaps can only be 24" or maybe 36 at most. Still keeps me under 100'
  6. rfulford
    rfulford Active Member
    566
    2
    18
    Feb 9, 2009
    Orlando
    It sounds like the rolls are really 33 yards.
  7. gabagoo
    5,723
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    yes this is the case although I was told by the sales rep 33 metres. Thats how I calculated I needed 3 rolls. Thats OK, I can get 8 on a roll and just need 1 extra that I can use a left over roll here for.
  8. stickermonkey
    stickermonkey Member
    212
    Ok...I don't profess to be a math wiz in any way shape or form...but 33 metres is the same as 33 yards ..no?? I may be wrong.
    Kyla
  9. gabagoo
    5,723
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    you live in Canada and dont know the conversion for metres to feet? lmfao who does!!!!
    well it is 3.3feet or 39" roughly
  10. stickermonkey
    212
    LOL...come to think of it...we're probably getting our materials from the same supplier...because last time I had a long run of banners I came up shorter than expected. I just thought I must have forgotten a job that I printed before starting that run. Hmmm...fishy...and another thing that happened to me was that they sent the roll of banner material without the plastic bag wrapped around it...so it was full of very small particles of dirt and debrie that nearly wrecked my printhead. It took me a couple weeks to figure out what caused the scratches...thankfully I was able to recover my head by doing several nozzle washes over extended periods of time. What company do you deal with for this material??
    I was just in Vaughan in May....I was actually looking for a shop I could stop into to see if I could get some ideas on how to organize and layout my shop to better manage our workflow. Where abouts are you?
    Kyla
  11. Rollie
    Rollie Very Active Member
    1,651
    Dec 20, 2007
    Ontario Canada
    1 meter = 3.2808399 feet
  12. V-ENGRAVE
    V-ENGRAVE Member
    Wow, Gabagoo - That is 8 feet short change if they sell you 33' for 33 meter. You should get to the bottom of this for sure.
  13. The Starflex brand has a count on the back that is marked every meter. This comes in handy when you try to figure out how tight it will be for that last banner. **** OK, I know someone will ask. I have never measured to see if the meter marks on the back are correct. ****
  14. gabagoo
    5,723
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    I be around Jane and Langstaff
    Cant say my workflow is any good though as I never did digital when I originally set up. I wish I had about 500 sq ft more these days as it is getting a bit tight
  15. GAC05
    GAC05 Major Contributor
    5,915
    787
    113
    Dec 27, 2005
    Guam USA
    I've run into this a few times.
    One supplier here buys by the container directly from Hong Kong so everything is in meters.
    I mark the core when I open a new roll and measure what is used on the trim out table - waste and all. Keep the totals in a notebook so I have a pretty good idea of what I have left. 1 or 2 rolls out of 6 or so will come up a few feet short. I try to stay at least 1 roll over what I think I will need to cover the shortages.
    wayne k
    guam usa
  16. Merritt Big Color
    Merritt Big Color Merchant Member
    The MFG's measure the linear footage by weight when they convert rolls.
    Ex. A 100 yard roll of 54 x 100 weighs 182 lbs (not accurate # just for discussion).
    I have come across this issue many times when running full rolls. Some are longer than they should be and some are shorter. It is all about the roll converter and its accurate calibration from your supplier.
    My suggestion is that if you think you have issues it is best to weigh the rolls complete with sono tubes or boxes as the are received. Keep the batch # and or lot # and record it incase you are shorted.
    Trust me getting screwed on linear footage is a VERY common problem and can contribute to a serious loss on your bottom line of you do not address.
    The only way to expose it is to run full rolls out. When you have a roll of media and you run a banner here and a banner there. You will never catch it.
  17. Slamdunkpro
    Slamdunkpro Member
    292
    We just recently had this discussion in this thread.
    We run a lot of banner in full roll runs and I'd say that on average 1 in 5 rolls of banner is short between 5-10 feet. I've also never had a roll that was over length by 5-10 feet.
    While we're on the subject of irritating banner trends - what's up with manufacturers starting to glue the end of the banner roll to the core with super non-releasing industrial strength adhesive so that instead of the printer feed pulling the banner off the core it drags the damn core up and into the printer feed causing all kinds of mis-feed jam and motor fault hell.
  18. gabagoo
    5,723
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    yup have had that happen only the roll is set in place and will not lift up...instead the printer prints the remaining graphic all in one line....one big strip of black!!! lol
  19. sjm
    sjm Member
    479
    gabagoo, 33 meters is not 108.9'. Give or take a few inches. What machine do you run?
  20. sjm
    sjm Member
    479
    What's the line length registration of your printer? My best printer is at .1% and over 25 ft that is a 3" difference.
