peavey123
Hi All,
We've been having issues with 3M IJ40 C vinyl. Laminated with a Select Source laminate rated for 4 years (which is great for calendared laminates lifespan) Used on windows. It's lifting around the edges after only about 1 year. Note the windows that are failing are in the sun most of the day.
Our issue is slightly strange to us because the vinyl is only failing for one customer that is a franchise at a few of their different locations.
Installs were all done in proper temperature ranges with proper techniques by our installer. No doubt in our installers skills here.
Is this material junk? I used to use Oracal 3651 RA for windows but last year we got talked into trying this stuff out and have used a few rolls for different applications, but mostly window graphics. Our supplier is telling us to use 3M 180...that seems nuts to me...what do you all use? Any thoughts?
My thought is either the laminate is a bad match, or the material is just junk...but it's supposed to last 7 years...so the weak point would be the lam as it's only rated for 4.
What do you all use for window graphics? Is there a cheaper (than IJ180) cast alternative that would be good?
Thanks,
Peav.
Thanks,
Peav.
