Can anyone weigh in on whether the denatured alcohol works as well?....any concerns substituting this for isopropanol?
Back in the day, many shops used denatured alcohol as it was readily available and inexpensive. The main use for it in all the shops where I worked was as a wipe for plastic prior to back-spraying with translucent sign paints. We
always cut the alcohol with water or it would streak. I usually cut it 2 to 1 which is roughly the same concentration as rubbing alcohol. Standard practice was to wipe only with a chamois to avoid introducing static which created havoc when spraying (and even when hand lettering). But I eventually switched to the synthetic chamois substitutes that came in a plastic tube at the auto parts store. They seemed to work as well and the tube kept them from drying out. Laundered them periodically or they would smell pretty bad. Conversely, paper towels and shop rags
always created static.
The three commonest alcohols used are methanol, ethanol and isopropanol. All are simple hydrocarbon molecules, but methanol is the simplest and cheapest. It is, however, highly toxic. Its main use is as fuel for race cars. It is also not uncommon to add a tiny amount of methanol to adulterate ethanol to make it "denatured." Without adding some kind of toxic chemical to ethanol, you would be able to drink it. All three of these alcohols are miscible in water, though only methanol is miscible in both water and oil. Alcohols are used as solvents in inks, paints, adhesives and many other things. Mixed with water, alcohol is an excellent cleaner that is not harsh. Used in a mix with some of the lacquer thinners (toluene, xylene, etc.), it becomes a decent paint stripper. The old T4000 Griplflex paint stripper for plastic faces was basically an alcohol mix.
None of which, of course, answers Chuck's question.
Brad in Kansas City
