Derf
OK,
I am hooking up my new ValuJet vj-1204 and it requires you to input the network data to configure the on board print server. SO I'm guessing!!
My IP config is as follows when I run an (IPconfig /all) on the PC running (Winxp Pro service pac1)
subnet = 225.225.225.0
Default gateway = 192.168.0.1
Computers on network
PC-A = 192.168.0.105
MAC-A = 192.168.0.104
MAC-B = 192.168.0.103
Copier = 192.168.0.102
Mutoh Falcon = 192.168.0.100
I set the ValuJet
Subnet = 225.225.225.0
Gateway = 192.168.0.1
IP = 192.168.0.106
In Flexi 8.1v1 on the PC
Production manager Setting for ValuJet:
IP = 192.168.0.106
port = 9100
What am I missing here?
Do I need to set up a DCHP static IP?
SW Said I need to run the printer direct to the PC using a crossover cable set with a static IP.
I know why they say that, because it is easy to set up that way and their job is to get the printer to work and not to manage your network. that is understandable, However A little network support would be helpful because I have 2 other pieces of equipment I need to run off the PC too. and lord helping I'd like to get the MAC to send print jobs too.
My Mutoh Falcon works just fine off the MAC and the PC.
Thanks for any Ideas.
I set the ValuJet
IP = 192.168.0.106
IP = 192.168.0.106
port = 9100
