estunum
We've had a wall mural gone bad 3 times now and wondering if there's anything else we might be missing. The mural is 10' x 10'. The substrate is 3/16" ACM, with a vinyl print applied on it. The print has an anti graffiti film instead of our normal laminate. ACM was applied to the wall with screws, then the vinyl applied over it. ACM doesn't come that big, so we had to place two panels, 5 ' x 10' each. Where the panels meet is the issue.
First time around, the client wasn't happy with how the seam showed there. Understandable, we didn't forsee that the ACM would not be perfectly flush so it tented in some places.
Our solution was apply construction adhesive behind the joint as much as possible. Sand down the ACM to make it as flush as possible, then apply bondo to smooth it all out. Seam was still visible a little but client was happy. Days later, what you see on the photo happens.
I assume it's the material expanding and contracting? Bondo didn't hold and just cracked by the looks of it. This mural faces west, so it gets A LOT of sun. Another thing I noticed is that our installer may have just screwed it place along the edges, because if you touch the center of either of the 5' x10' panels, you can push it down maybe 1/4". Is is just that the panels have too much give?
My suggestion from the very beginning was to just cut the vinyl where the panels meet, so we'll have to suggest that again, that it will be something they simply will have to deal with. If there is something else however, I am all ears. a solid 10' x 10' panel would be ideal, but none of our vendors carry it, probably doesn't even exist.
