ADA braille signs - need help
thinksigns
SnowFlake
We do not do braille signs in house, and all the ones I have ordered in the past have been of the "Suite 204" variety. I am being asked to quote all the signs for new condo building. The Fire Marshall provided the copy for the sign, but he could not tell me if all the copy on the sign has to be reproduced in braille. All he could say was braille is ADA stuff.
Looking up ADA braille regulations addressing my problem has proven impossible.
On a side note, my customer said that the wording could be cut vinyl and did not have to be raised. I did find wording that said it had to be raised.
I have attached samples of the signs.
Any help would be appreciated.
AzGene
All of the ones I have done in the past just had the stairway designation and the floor number. But I can't say that applies in your area. Odd the fire marshall doesn't know, they are usually the ones to approve the signs.
StarSign
Looking at the copy there is no room for braille so just get the FM to sign off on the signs as is, let him make the call to CYA. We do alot of ADA and I have never seen anything like this that needed braille.
petepaz
do you have anyone local that does engraving. we have a guy who does ours with his engraving machine. ( i am not sure on the ADA braille regulations, he takes care of all that) also you can order them from seton but they aren't cheap
thinksigns
SnowFlake
I don't have anyone local.
It is (10) like the samples I attached. (54) 6" x 6" and (60) 2.5" x 4"
If anybody has a supplier they know and trust, I would love to get a second quote.
ChicagoGraphics
You can check with Grimco, I know they make stock braille signs they just might do custom orders as well as long as you have more then a few.
Malkin
We use Clarke Systems or Scott Signs for most of our Braille ADA needs.
Also, Rick (on this forum) is very knowlegable on the subject, hopefully he could chime in...
rick the circle maker is your guy to ask. However, I've never seen a storybook written for ADA signs like that.
You're probably going to have to figure out a condensed version and have it approved.
TheSnowman
C&C Engraving in Arizona. Used to be a MM here (or at least advertised here, cause that's how I found them), not sure if they still are. They do that stuff all day long. Talk to Gene...he's gone above and beyond for me on a few jobs lately. Great work.
AzGene
Thanks for the kind words Kraig. Don't think I did anything special, just taking care of business. And, yes , I'm still an MM here.
Rick
Tactile and braille is not required for that sign type.
There are other signs that usually go in that area.
A floor designation sign inside the stairwell (just a floor number and at the floor where you exit, the floor number and a raised star)
There is probably supposed to be a evacuation sign at the stairwell landing and elevator and main exits. At the stairwell landings, there is usually an ADA incorportaed that says the stair number and the type of exit (like EXIT STAIR UP, EXIT STAIR DOWN, EXIT ROUTE (OR PATH)
At now we are required to have ADA signs where illuminated exit signs are that describe the path.
if it was required to be braille, the lettering would be required to be raised as well.
i'm also inclined to believe that these don't fit in that category. Never hurts to simply ask the fire marshall. He should be able to simply tell you what he's looking to sign-off on, as the difference in cost between braille/raised lettering and vinyl graphics is HUGE... especially in the scale your working with.
also added: he should have approved similiar signage in your area, maybe check out a public building while you're out at lunch?
Rick
This seems small, is this the size the fire inspector gave you?
That type of sign usually is a minimum of 12" x 12" with non-glare finish
Usually there are type face requirements.
On the floor designation, it's 5" cap height and a certain stroke width.
On all other type - usually "ROOF ACCESS" and the information of what floors the stairway services like "1 THRU 15" and the stairwell id "STAIR 5", it would be 1" cap height and a certain stroke width.
I think in this case it might be too much sign, I would have the smaller copy a minimum of 5/8" cap height.
Oh and I'm surprised it has "northeast stairway" In a building, especially in an emergency, that means squat. Most people looking for a stairwell in an emergency, even a firefighter and police officer will get turned around. The Architectural plans should have the stairwells titled. In an emergency, there might be a chance that someone may use plans to map out an emergency plan, and if the architectural plans do not match what is on the sign, that can be dangerous... at the very least it's poor planning.
thinksigns
SnowFlake
The larger signs are about 14" x 10"
The 6" x 6" are for misc rooms (trash, mechanical, etc.)
The smallest ones are for the condo unit numbers
All of the information on the largest sign was on the Word doc the FM sent me.
All of you have been very helpful. Thank you. I hope to get this figured out in the morning.
lassiter
Texas Code requires raised copy (Floor# 2", all other copy 1") and braille. And like Rick said, the roof access information is required. We typically add re-entry information, if the sign is going in the stairwell. If the door will lock behind you when you exit, what floor you can re-enter the stairwell.
Everyone make sure to remember, the revised ADA guidelines go into effect March 15, 2011. Make sure when choosing a signage manufacturer, they are knowledgable and current in relation to ADA codes. This blog addresses some of the new ADA changes..
http://dixiesignagesolutions.com/blogs/signage-solutions-blog/2012/02/21/new-ada-standards
With your website there.... after checking it out, why don't you consider opening a Merchant Member account with Fred. Then you could post your wares fairly and make potential money while doing it.
MeganJones
Thanks, Gino. I will look into it! I just found this forum today, so I am new to it. After looking at all of the threads, I am excited to join in on these conversations! This seems like a great place to bounce ideas.
