Advice Needed: Brass Letters Inset into Marble Floor Circles
nolanola
https://manhattansignshop.nyc/
I’ve been approached for a project that involves insetting brass letters into two 54-inch-wide marble circles in a lobby. The marble is part of the existing floor, and the brass letters need to match the style of an existing inset lettering design (photos provided by the client).
Here’s what I’m trying to figure out:
1. Marble Removal vs. On-Site Work:
The marble circles are fixed into the floor. Is it better to remove them for CNC engraving, or should I bring a portable CNC machine to the site?
If anyone has experience with marble removal, how risky is it for a piece this size (54 inches wide) without causing damage?
2. Portable CNC Machine Recommendations:
Are there any portable CNC machines suitable for engraving large marble surfaces on-site?
If you’ve used one, how is the precision, and what should I consider during setup?
3. Brass Letter Installation:
What’s the best adhesive or securing method for inset brass letters in marble?
Are there sealing or finishing steps I should take to ensure long-term durability and match the existing look?
This is for a high-visibility project in a university building, so I’m looking for advice on achieving the best possible result. Any tips, tools, or lessons from similar projects would be greatly appreciated!
Thanks in advance for your help!
James Burke
The safest, most precise, and the most economical way to do this is by abrasive water jet. Cut the marble, cut the brass, polish the brass, and then install. No two ways about it.
JB
nolanola
JB
Thank you for this.
I understand it's important to use the same equipment for cutting so it matches perfectly.
This isn't advice on 'how to' but do you think you should be cutting your teeth on marble and brass for your first try at this sorta thing ??
Maybe find someone in this line of business and go along with them and don't take any commission so if someone goofs, you're not connected to it.
James Burke
would make a circle template same height as brass letters and pour epoxy to match marble, after drying sand entire piece.
Matthews offers bronze plaques that are in-filled with a composite granite admixture. This would be the most durable long-term solution aside from using solid marble.
JB
