toomeycustoms
Machine is a SC-545ex. Our black head nozzle check is not printing well. We have changed out all 6 captops, wipers and scraper. We have soaked the head multiple times and even overnight with little change in the nozzle check. We just had a dx4 printhead overnighted and plan on swapping the head out over the weekend. Anyone have any advice/tips on the swap?
Here is my plan of action:
1. Pump up(In ink control menu) the B group to remove ink
2. Input head rank. I noticed on my replacement there are 5 lines of text. Are all 5 lines entered or just the first one? If all 5, there seem to be spaces and periods, is that normal?
3. Unplug machine from wall
4. Remove covers and unplug cables and dampers.
5. Remove spring on head and then remove 3 screws
6. Affix new head to adapter
7. Install head, install spring and then cables and dampers.
8. Plug in machine and go into service mode.
9. Go into ink control menu and select head replace b group.
10. Perform head alignment and clear head info.
