Alignment Problem Sp540v
Discussion in 'Roland' started by bertex, May 14, 2007.
  1. bertex
    bertex Member
    39
    Anyone have this problem? The print starts out fine then runs off the media. A tech told me cleaning the clear strip behind the heads, that worked for a while but now, I can't print anything perfectly straight?:help:
  2. mark in tx
    mark in tx Very Active Member
    2,081
    Oct 25, 2005
    Harker Heights, Texas
    How old is the machine?
    I just had to replace the sensor that reads the strip, but my machine is 18 months old.
    Depending on how adventurous you are, you can try flipping the strip over.
  3. SignManiac
    SignManiac Major Contributor
    8,494
    37
    48
    Mar 25, 2006
    Mars Florida
    Mine just started acting up this weekend. It's been locking up with a "carriage is disconnected" error and we have to reboot and start the print all over. I'm waiting now for tech to call back.
    Like yours the image is printing skewed even though the media is perfectly straight. I think it may be a calibration issue.
  4. ChiknNutz
    ChiknNutz Major Contributor
    4,789
    2
    Mine has done this a time or two and is the encoder strip that has been previously mentioned.
  5. bertex
    bertex Member
    39
    Yep, about 18 months. Can you say built in obsolesence, or what. Right now I've got about 40 banners to print, so I'm getting real adventurous, also waiting for a tech to call.
  6. BobbyFosson
    BobbyFosson Member
    401
    Encoder strip and/or encoder sensor may need to be replaced... another thing that can cause this is loose wire tension on the carriage wire.
  7. customsticker
    customsticker Member
    145
    Get some isopronal alcohol and rub down the encoder strip.
    It more than likely needs to be cleaned. It goes from left to right on the printer Iabout 54" long, has thin lines in it). Also, check the sensor that reads this strip. This sensor goes over top of the strip. If you can find the strip, you can find the sensor! Dust can really cause some major issues with them. If it is dirty, it won't print correctly.
    It may need to be replaced - but try cleaning first.
    Get a flashlight and look around - I bet you can find some dust in places you didn't know existed, and can cause problems.
  8. threeputt
    threeputt Very Active Member
    3,389
    1
    38
    Mar 10, 2006
    washington state
    It's almost for certain the sensor strip. They are $225.00. But....before you do that, take it out and very, very carefully clean it with Isopropyl alcohol. Do not use denatured alcohol!
    Clean it both sides with a really soft white cloth. Replace it. If it doesn't improve dramatically, then it's probably the sensor. It may simply be dusty. Blow it off with canned air.
    Finally, the carriage cable has to be set to 11 lbs. tension. It's fourteen from the factory, but they wear in and finally settle at about 11. Ours was getting saggy, down to seven I think the tech said. That is probably not your problem. But if you're going to have a tech out, then definetly have him tension it. (takes special knowhow and tools, I think)
    Hope you get 'er running pretty quick.
  9. bertex
    bertex Member
    39
    Thanks, guys - new encoder strip and sensor on the way. Hmmm 1/2' x 54...thats .1875 square feet, about 1100.00 a square foot...seems reasonable...
  10. threeputt
    3,389
    1
    38
    Mar 10, 2006
    washington state
    You got your for $206.25? Hey, that's a deal. I paid $225.00. By the way, how much is the sensor?
  11. bertex
    bertex Member
    39
    276.00 for the strip, 146.00 for the sensor, still not printing. Waiting on tech, day 3 no printy = bad week for me.
