hello all, i have a customer that is looking for "an indestructable sign", i said that's a relative term and if someone really wants to wreck your sign they will. so i tell him i can laminate it with anti graffiti laminate. now my question is, is it worth the extra money for this laminate, and does it really work? it says to use lighter fluid on the oracal site to remove spray paint and markers, etc. but if i remember correctly that someone had mentioned using vodka for removing spray paint off normal laminate. i will be using cast printing material, plus a cast laminate on alumabond sign board, mounted to plywood and 4x4" posts, they are looking after the mounting i am just supplying the signs. so will normal cast laminate be enough and can you remove spray paint and markers from it and if so how? or do i need to go with the anti graffiti laminate?
thanks, jkl
thanks, jkl
