Paint the Town
Hello,
I'm new here and was hoping that we could find some answers to a problem we're running into.
We're using 3M Removable Reflective IJ680CR-10 vinyl to apply graphics to some Chevy Sedans and we are running into the issue of it beginning lift from the flat surfaces. It is not horrific but definitely noticeable and undesirable ofcourse. This lifting has even begun within a couple hours of applying the grahics. Has anyone run into this problem?
We are thinking it may have to do with the time we allow the vinyl to cure after printing before we laminate. The times have varied for us depending on the work load for the day and has been anywhere from an hour to 24 hours before lamination. Could not giving it enough time to cure be the issue?
We clean our surfaces with alcohol and do a post heat after applying. Our printer is a Mutoh Falcon II Outdoor 64". Any help with this issue will be greatly appreciated!![Notworthy :notworthy: :notworthy:](https://signs101.com/images/smilies-orig/standard/notworthy.gif)
