GS6000 extended warranty
We are about 1 week away from buying the GS6000. I'm getting doubts reading about the take up reel, reduction belt, head strike, green streaks problems... Do you know how much the extended warranty is?
Donny7833, The reduction belt may be over tensioned. Ask the technician to show you his tension method and spec he is using. He should be using some kind of force gauge to measure this.
The green ink will always be an issue because most rips use the green channel very little or in some cases not at all. Updated versions of Colorburst and Onyx do a better job with using the green channel, but clogging in green could still be an issue with machines that are used less than 10 hours per week.
Head replacement costs can be large $$$. New owners should budget for post warranty service or extended warrantees.
