phototec
The only time I ever had an issue like that, I was trying to install white 751 on a windshield and it was because the owner had used Rain-X so water would shed and bugs would not stick to the glass.
I tried to remove the Rain-X, with Windex, alcohol and Rapid Tac cleaner, nothing would remove the Silicone based rain-X.
So, used Google and and found out it is hard to remove Rain-X, however there is a process to remove it.
My vote is there is some type of wax or Rain-X (Silicone coating) on the air dam to prevent bugs etc from sticking on the surface, that and the combination of cold and snow caused the decal to peel off.
I would suggest doing a test, try cleaning an area on the air dam as if it had some type of Silicone coating, remove accordingly, then re-install the 751 and see if it sticks like it should.
As others have said, I have used old 751 and it stick grate, no issues.
Check this out:
http://www.detailxperts.net/blog/2014/08/18/remove-rain-x-film-windshield-5-easy-steps/
Check this out:
